KX 161-3 Digital Control panel language change
klansdell
KX 161-3
Mar 29, 2012
Murillo, Ontario, Canada
Hi Everyone,
I've picked up a second-hand excavator. Unfortunately, I don't know much about its history. I've noted that the digital display is in Japanese. Is there a way to change this to English, or would I need to replace the display module to achieve this?
Thanks in advance!
4,219
I don't know for sure, but I'd suggest that you start here and see if you can find where it is in the settings....
There is also a link in this thread to the WSM for that model. Go to the last page of that thread.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
735
640
E.
on mine to switch between french/english, when machine is off, you hold down the display selector switch then turn the key to the run position (not to the start ).
lift finger off the display selector switch.
then press again and again the display switch until the right language choice pops up. Mine does
not give Japanese option though only french/engrish ??.
once the right language you wants shows on the disply press and HOLD the display switch until your choice is stored.
