Hi there!
I’m looking for some help with my Kubota v2403.
There was some job done with injection pump (one section was stuck). After that engine is totally out of control: revs are going up to some crazy level, there’s no response to throttle, I can’t shut off engine with key (solenoid is ok). Only cutting off diesel or air can help to stop this mess.
I checked the sliding element on the side of the pump. I didn’t hooked it to governor lever correctly so I made it as it should be. But even after that there’s no improvement. I checked it once again: two springs on governor lever are located right in place and they’re not stretched. Also, levers are working fine, fuel pump isn’t jammed and fuel pump rod is sliding in full range from left to right. I’m suspicious about one thing: I have to put some effort to hook this sliding rod correctly to governor lever (I have to put the pump a little bit into casing, then manoeuvre the lever max to the left and last put the rod in right place with screwdriver pushing rod to the right. It’s a bit complicated and need to put effort to make it right. From my point of view it look like governor lever lacks range to hook easily with pump.
Is it possible that I damaged something or rotated governor lever in housing as I put the injection pump for the first time incorrectly? Desperately need some help, Kubota KL series is not very popular in my country and M-series (which is quite common) guys have no experience and no will to help.
