Kubota s2800b engine
Jackjagg
Kubota engine s2800b
Jan 5, 2022
10
Hi does this Diesel engine have a block heater or can one be installed.
What location on engine would heater be.
Thanks
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,966
1,626
WestTn/NoMs
I'm 99+% sure it didn't come standard with a block heater.
The S2800A was used in M4950 tractors, so a Kubota dealer might could help you. It may go in a freeze plug hole.
The S2800B was apparently used in a skid loader. What is your engine powering?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,966
1,626
WestTn/NoMs
You can also install one in the lower radiator hose, if there's space. Some on here prefer that.
Jackjagg
Jan 5, 2022
10
Hi yes there is one installed but don’t feel it’s doing job. Right at the in-line is hot but I have put my hand around to feel for warmth don’t notice any.
Are these inline heater supposed to work by a siphoning action? Don’t feel any mechanical part moving coolant.
I should feel the rad coolant warm if plugged in over nite? But it’s not.
It would be easier maybe to change that inline with one that moves coolant.
I have installed a heater in cab tied into the from motor to rad at the return to rad. Works fine. Butcould that affect the movement of heated coolant?
Thanks
Jackjagg
Jan 5, 2022
10
Just a test removed hose’s for cab heater I’ll see if I get warm coolant movement.
It’s about 8 or 9 ft of hose and maybe another 12 inches inches above motor height or maybe abit more 14 or 16 inches
Thanks
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,966
1,626
WestTn/NoMs
Thanks
Sorry I can't be of more help. I'm in southern US and never had a heater.
Jackjagg
Jan 5, 2022
10
Thanks for reply’s thinking of going with a inline circulating heater . Are there any specific ones people use and like?
My lines are 2 inches.
Thanks
Jackjagg
Jan 5, 2022
10
Well after getting info on the correct part number I hav purchased block heater which sitting in machine will go on left side by fuel pump/ lines . Went to -35 last lol don’t think I’ll be installing today still -27 outside with good .
Thanks for reply’s
Jackjagg
Jan 5, 2022
10
Ok thanks and update pulled frost plug and installed heater, bloody cold one.
I then let machine sit for 1 1/2 hrs tried starting wow sweet fired right up. Ok all set for these cold days
7,766
Don't run the block heater all the time, 1: it will burn out faster then you would like, and 2: it will really hurt your wallet, they pull a lot of amps.
Plug it in about 2 hours before you want to use it.
Jackjagg
Jan 5, 2022
10
Hi looking at pulling the Kubota s2800b diesel motor this summer. Checking if anyone has wsm to share for this motor.
Thanks
