Kubota M9000 turns over but does not start
Benk10
Kubota m9000
Oct 10, 2024
Shiner tx
I have a Kubota m9000 it will turn over but not start, but only sometimes. Sometimes you get in it and it will crank right up. Other times it will just turn over and not start. If you go back a couple hours later it will start right up. When it starts it runs for hours like normal. Right now it is not wanting to start. We checked all the battery connections and cleaned them.
5,988
I think your trying to say it will crank but not fire and run at random times, right?
If so what you are describing sounds like an issue with the fuel stop solenoid.
Get the WSM and read how to test that part.
Benk10
Kubota m9000
Oct 10, 2024
Shiner tx
Thank you sir, you are correct. We first tested the fuel pump and discovered that it was not working. Once we replaced it we got all the air out and it still wouldn’t start. Come to find out the fuel stop solenoid wasn’t working either. What are the odds… thank you for your help!
