I have axle oil leaking out of the area where the main front axle bolts to the right wheel assembly case. According to the attached photo below it looks like the oil is leaking because the "o" ring must be bad (I'm surprise there is not a normal gasket that seals when the two components are bolted together).
1. Am I right the only seal to join the two components is solely the "o" ring?
2. Can a normally mechanically inclined person be able to replace this?
3. If I do tackle this job are there any do's and don't's or tips that I should be aware of?
I appreciate your help.
