So yesterday the gf was drivng the tractor and she refuses to learn how to push a clutch in or use the throttle lever. I'm usually by her and try to talk her through everything as she drives. Of all days I stopped to fix a rut she made and next thing I know I hear screams and see my tractor drive straight into my small pond. She didn't push the clutch in, didn't shut down the throttle and didn't hit the shut off lever. She just hit the right brake yeeting it into the pond. Now it didn't spit a rod out of the block but it bent a rod. I took the exhaust off, turned it over w the decompression lever on and got the water out. Then fired it up shockingly it started but number 3 cyl just puffed white un-burned diesel. So I pulled the injectors and saw numb 3 piston didn't come up as high as the others. So what engines will fit in the same spot. It has a d1101 engine. I'd like to upgrade to maybe a 28hp engine. Here's the link to the video of it in the pond.
No way that just happened 😳
Scarlett driving the tractor hits the right brake instead of pushing in the clutch. She drove it straight into the pond.She's ok but the tractor is not. So ...
youtube.com
