Kubot M62 Max Size Hydraulic Box Scraper/Gannon
Keith Levin
Kubota M62
Jan 6, 2024
Northern Arizona
Question for anyone familiar with the M62 TLB:
Would the M62 handle the beef of a Case 440 hydraulic scraper on the back end? looks like it specs out at about 560 lbs heavier than the Land Pride HR3584 which is the typical scraper I see installed. Thoughts? Extra front ballast?
Thank you!
6,207
It's within the weight that the three point can lift and the tractors weigh about the same.
So I don't think you would have an issue using it.
mikester
M59 TLB
Oct 21, 2017
3,525
1,986
www.divergentstuff.ca
You might want to use something a little narrower as the M62/59 is a lightweight compared the a full sized case TLB tractor. You can use it but it will be at the limits of your machine.
Burrdog
l3650, L5450, M59, Dresser 518, IH 8400 SA dump, FrtshakeFL120, Trail king TK24
Thank you!
Bit of a late reply here on my part, but possibly others may benefit from my experience. I am running a M59 with 7foot Gannon High Back hinged cutting edge box, most likely from a case 480LL or a Deere 310LL and these boxes are HEAVY!!
The M59 handles it well. If you have box blade experience you know with the lack of 3-pt down pressure box weight is your friend. My L5450 can raise this box but it doesn't like it.
Gannon boxes are the best, all others are a second, but good condition ones are hard to find, especially the 6.5 foot Gannon box that was made and branded for Kubota in the 90's.
Don't even consider adding a box without 3 spool hydraulics to complement it, the finish grading abilities are surprising and the hydraulics open up a world of attachment options.
Hope my experiences can be helpful to others. Thanks for this great site
Burrdog
