Jerky loader when lowering heavy
Bearcatrp
Mar 28, 2023
512
268
Minnesota
Have tried to be super easy on the joy stick when lifting near max weight but it’s still jerky. Have other posts on larger tractors that there is a way to adjust it. Is there a way on my 1880 to adjust the loader so it’s smooth when lowering a heavy load? Thanks
Grandad4
Apr 5, 2016
301
64
Greensboro, NC
Do you have anything on the back to counterbalance what's up front? Getting it somewhat balanced will help a lot. Think of an orange teeter-totter with a heavy kid on one side and a really skinny one on the other.
4,644
might try reducing RPMs.....
My BX23S is real jerky when compared to the forklift !
Yeah, i 'could' fix it..
one way is to 'regrind' the spool valves for smoother action but I ain't a machinest...
other way...replace the valves with electronic ones,run them in constant current mode, have PIC as the 'computer', use electrical joystick. Cutting code is easy.
4,048
Pretty much the nature of the valve - they dont meter well and it is most noticeable on heavy loads.
I dont know of any way to "adjust" it on any tractor.
Meadowbank Kubota
BX1880 with an LA344s
Aug 23, 2021
17
9
Cornwall, PE
I don't have a very steady hand so I find holding the joy stick down by the boot keeps movements small and it operates more smoothly
Bearcatrp
Mar 28, 2023
512
268
Minnesota
Have about 300 lbs ballast in the ballast box on back. Always have that on when using the loader lifting heavy stuff.
