Install of water temp gauge - L245DT
John RHR
L 245 DT (emeritus) L3902
Oct 11, 2013
Lake County, Calif
Folks -
Maybe I'm blind - but I am looking for a place to install a mechanical water temp gauge in my L245DT. I am not seeing any obvious pipe plugs - can any of you assist? Also, if there isn't a plug to install the gauge, how about simply wrapping the sender tight against the upper radiator hose with heat sealing tape - not the best, but at least would give me something. Looking for your feedback - thanks!
Selah,
John
kubotasam
Apr 26, 2010
1,202
128
Alfred Maine
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
638
249
Herald Calif.
Hello
You should have a plug on top of the head that you can remove and install a gauge. Right rear corner , just behind the last injector.
Good Luck Lance
mattwithcats
776
66
Is that a 1/8 -27 NPT threads?
The oil is 1/8-28 BSPT, same as Subaru's (hint hint when looking for an adapter), LMA Auto parts has a "T" on the end of a 30 millimeter hose, works great moving the oil pressure sender to another location....
I do like the little Auto Gage water temp, very small, but it's a digital sender, no tubing,,...
https://www.amazon.com/gp/product/B00062YVWK/
All three, water temp, oil pressure, and volts...
https://www.amazon.com/Auto-Meter-2391-Autogage-Electric/dp/B00062YW06/
5,468
Not sure on the L245, but on the L305 I'm pretty sure is a 12 X 1.25 mm. I got the adapter fitting at the local O'reilly Auto. It was in a package of 5 items hanging on a peg by the meters! (the counter guys didn't know they had them)
6,208
Because it's a plug with a sealing washer it might need a BSPP fitting. ;)
JunkyardDog
L245
Nov 16, 2018
19
Cypress, TX
Did anyone complete this task? I am looking to add a temp gauge. The electronics are not an issue. I want to be sure the sensor placement is appropriate.
Has the threading in the block or head location been confirmed to be NPT or BSPP or any other variant? I am familiar with NPT. Not so much with BSPP, BSPT, etc. I am also assuming that the port mentioned in an earlier response is the one I marked with a red circle/oval in the attached picture. Is this correct?
Without some feedback, I am leaning towards fitting inline of the hose. I am not sure how reliable that would be. Any thoughts on this?
6,208
It BSPT, most Gauge kits meant for foreign cars will have the proper adapter in the kit. ;)
6,208
Thanks!
By foreign cars, would it be more exclusive to any region? With the 'B' is BSPP being British, I suspect at least European.
BSPP = British Standard Pipe Parallel
BSPT = British Standard Pipe Taper
Japanese, German, British, and quite a few others use BSPT sensors. ;)
fj40dave
Sep 24, 2009
421
256
Yelm, WA
Hi all,
I'm freshening up a L245DT and wanted to install a temp and oil pressure gauge.
Not finding the plug in the top of the head like I did for the last L245DT temp gauge I installed.
Would the "in line" water hose install be the only other option?
I took out the block drain plug, and that won't work.
6,208
Hi all,
Not the in line (bottom) but the out line (top) radiator hose is where you put it. ;)
Bottom will give you a false reading, as it will give you a cooled reading.
fj40dave
Sep 24, 2009
421
256
Yelm, WA
Out-Line.....gotchya :)
Thank You Again NIWM!
Hope you & the fam are staying healthy over there!
fox87stang
L-305
Oct 30, 2020
Hi all,
How did you install this into the outlet of the radiator? Was there a special adapter or piece that allowed you to bolt into the hose?
fj40dave
Sep 24, 2009
421
256
Yelm, WA
I ended up using the drain plug outlet.
The "in-line" choice was too big to fit with the short hose lengths, and I also didn't want to be back fixing any leaks later on (the tractors get used by various employees and their "love" for them isn't always sincere!) :)
L275
L275F, L2850D, BF500 Loader, FS1020, M5-4 Cutter, 500 PostDigger, CRB60 Blade...
Jun 8, 2019
40
Naples, FL.
Hi all,
This option is more expensive but with a 1/2" NPT sensor port it may be the best option if using a mechanical temp gauge. Many others have smaller sensor ports so the sensor size is important.
Some may have a less expensive route for a suggestion on a mechanical temp gauge.
L275
Jun 8, 2019
40
Naples, FL.
Hi all,
It may be the other plug as shown in the picture.
SonofOrange
L245F with 1200 loader, T1870, AT70, GL-5500(S)
Sep 1, 2021
101
Monroe, GA
This is on my short list of things to do. I'm interested if it worked and how you did it and where you mounted the gauge. There is not much operator space these mid 1970's tractors.
Thanks,
Mountain Man Mike
L245DT
Mar 11, 2022
Northern CA
I installed my gauges right above the steering column on the sloped cowling which was the perfect angle for good visibility through the steering wheel. I used 5" long pieces of DWV black plumbing pipe to house the gauges, as I could not locate a three gauge exterior mount to my requirements. I use the bungee cord to keep a clear baggie over the gauges in rainy weather as they are not water resistant as was described and the temperature gauge fogs up internally if rain hits it directly. I plan on adding a third gauge for oil pressure that comes with audible and visual alarms for low pressure. The wires and tubing go into the engine compartment where the hood opening gap is. No wire pinch occurs.
My L245DT had the plug in the head for mounting the temperature sensor. Because yours does not have one I suggest you might try a properly sized radiator hose adaptor from Amazon like this:
https://www.amazon.com/Universal-Te...se+adapter&qid=1648523091&s=automotive&sr=1-5
Let us know how it turns out.
