Hydraulic/Trans Oil Fill For L2550 & Drain Plug Question
plumber mechanic
Kubota B8200 with rc60-82h mower deck, Kubota L2550D
Sep 18, 2023
40
I just picked up a Kubota L2550 column shift with loader. The owners manual shows two different caps to add hydraulic fluid. One is above the transmission (between the foot rests) and the second is behind the seat at the of top of housing where the 3 point arms are hinged. Are both of these one in the same...in other words if you add oil to one does it also adds to the other? My owners manual does not specify whether "either or" is an option to refill both at the same time. I have a site guage on the left side of the transmission near the clutch and need to add fluid to get it up to normal level.
Also, on the underside of tractor under the clutch area (just behind the engine) there is a drain plug with a little silver ball that is slowly dripping oil. The ball is part of the drain plug and can be pushed up and down but will drip oil when left alone. If I replace the plug is this also part of the hydraulic system? What's the purpose of the ball?
Any help will be appreciated.
1,327
The plug is to drain water and stuff from the bell housing area. I thought that Kubota used a cotter pin up through the hole in the plug so perhaps you are seeing the round eye end of a cotter pin?
As (as far as I know) the same sump is filled by both of the fill ports.
EDIT=correct “the h” to “the hole”
6,062
Yes the fill point both end up in the same place.
That is called a split pin drain.
Having hydraulic fluid leaking from there is not good.
You will need to split it to get to the seals in there.
DO NOT put a non draining plug in place or you'll just fill the clutch housing with oil and damage the clutch.
plumber mechanic
Sep 18, 2023
40
The plug is to drain water and stuff from the bell housing area. I thought that Kubota used a cotter pin up through the h in the plug so perhaps you are seeing the round eye end of a cotter pin?
Thanks for your information
plumber mechanic
Sep 18, 2023
40
Thanks for your reply....I intend to install the same type of plug from Kubota. When I remove the plug I assume lots of oil will drain out?
4,949
The split pin drain shouldn’t leak anything in the ideal world when removed. The area that plug (it’s not really a plug but a drain) is located shouldn’t have oil or water in it but can build up both due to condensation and seal leaks.
That drain is designed to leak stuff out if it gets in there so the clutch, etc. don’t get wet.
6,062
Yea like RCW said, no need to change the plug / drain as it's working perfectly.
It's seals / gaskets inside there that aren't working.
5,367
The original design of that opening was to let water drain out when the tractor was used in rice paddies. The loose cotter pin was to keep thing from going in the bell housing.
plumber mechanic
Sep 18, 2023
40
Thanks for your help.
