Hydraulic Lines
Stmar
B2650HSDC
May 23, 2017
910
42
Buffalo, Wyoming
How often do you have to replace faulty hydraulic lines? It seems like I replace one a year, not the same one, very light use and no abuse or accident. Only about $15 so no big expense, just a pain since the dealer is 50 miles away. Tractor is about 7 years old and stored in barn, don't know how long hoses are supposed to last.
3,663
A decade or more going on two. Why are you replacing them?
Stmar
B2650HSDC
May 23, 2017
910
42
Buffalo, Wyoming
The hoses are deteriorating, leaking from hose and not fitting. No rubs/abrasions, no bending or flexing to any degree. These are original hoses, have not had any of the replacements leak so it's not the locations. Always stored inside so no sun damage, just wondered if anyone else had similar issues.
4,680
Must be a breakdown in quality of materials in your machine. This past winter I had to replace two hoses on my 1966 Case 730. They were original hoses! I have some other machines and I've only replace one other hyd hose, and that machine has set outside for a long time.
4,197
By BX22 was constantly having leaking or burst hoses after about 12 years. The pressure was factory set and I never messed with it. I attribute the problem to the smaller hoses were not as stout as the hoses on bigger machines.
3,663
I attribute the problem to cheap poor quality hose.
mikester
M59 TLB
Oct 21, 2017
3,279
1,752
www.divergentstuff.ca
Hoses last until they break. Most recent for me was a pressure washer hose bursting. No rhyme or reason, stuff just fails when it wants to. Luckily blew away from me at the time.
4,479
All the hoses on my 1989 Ford 1920TL are original.
35 years old.
