Hydraulic fluid filters
Ryeder
B2650 hsd
Feb 10, 2022
15
NH
Good day. I have a situation that maybe someone has dealt with. I have a 2018 B2650. I ordered a set of hydraulic filters that were advertised for this specific tractor. When I went to install them, they didn't fit. The threaded female connection on the filters themselves were too small. When I reported this to the company, I was told that they had sent the right parts. Does this model tractor have different filter requirements? The company is adamant that they shipped the right filters.
2,731
The first question we all want to ask - WHO/WHAT is the company that you got the filters from?
My advice is to send them back - go to your local Kubota dealer and get a couple of these filters - so that you will have another one when the time comes.
This is not the first time that company "X" says their filters fit product "Y"
Go ahead and get the real filter from Kubota - in the long run you may have paid a couple or bucks more BUT you will have peace of mind knowing that it fits and does the intended job.
Elliott in GA
Mar 10, 2021
764
752
North Georgia
You might be better off that they do not fit. Who knows how they compare to the OEM filter on the inside and in every other way? As recommended above, just buy the OEM filters and fluids.
A couple of Messick's videos about filters.
Ryeder
B2650 hsd
Feb 10, 2022
15
NH
Thanks for the reality slap...lol. Stupid is as stupid does according to Forrest. The company is Road Parts out of CA. That in itself should of been a warning. Guess it's time to loosen the purse strings and go see the dealer. Thanks again.
5,130
I will go against the OTT grain here.
I use Baldwin (industrial quality brand) filters without issue.
2,731
I use Baldwin at work AND on my B7100's at home - never a problem.
8,198
There are some manufacture name brands that are good.
5,130
That's not going against the grain...They're good filters!
I know that Baldwins are good filters, but others will constantly preach Kubota ONLY.
...........As if Kubota makes their own filters.
8,034
Here's my take on this topic, and for the record, I don't think I've ever suggested that Kubota filters are the best choice, but they are the only guaranteed choice.
There are no industry standards for oil or hydraulic oil filters as there are for engine oils and other automotive related items such as engine coolant. In the case of engine oil, as long as the oil that you use meets the requirements listed by Kubota in the owner's manual then all is good. But there are no requirements or specifications listed for filters so how do you know that you're buying an equivalent product?
How do you know that your choice of non-Kubota filter meets Kubota standards? You can bet that Kubota has filters made to their requirements or standards regardless of who makes them, or where they're made. When you buy a Kubota filter you know that it's got Kubota's stamp of approval but that's not the case for other brands, that might actually be better, or a lot worse. If the cost difference were huge I might be looking for alternatives, but since it's not, I buy Kubota filters which are readily available just 3 miles from my house. When the dealer moves much closer to the center of town later this year, I will still buy Kubota filters, but not because I know or think of them as being superior, but simply because there is no doubt that they meet Kubota requirements for flow rate, particulate size, longevity and integrity.
For those that use other brands, what's the flow rate and micron filtration rate of your choice of filter, and how does it compare to the equivalent Kubota filter? Also, how does the filtration media in other brands react over time when exposed to UDT or UDT2? I would expect Kubota to have tested for these kinds of variables but can the same be said for other manufacturers?
