Hydraulic Control Valve mx5100d
Bulletsnbait
MX5100D
Oct 12, 2024
Frankford, wv
I have a hydraulic leak from my loader control valve. It's pouring down the 3 standard lines going to the tractor. The quick connects are not leaking. Tractor is 6 years old. I unscrewed and put permatex on the couplings and reinstalled and it's still pouring the fluid. Mechanic friend thought it was the lines. I think it's the block. Before I go buying new lines, and a 1000 valve, can I install an aftermarket control valve on the la844 loader on an mx5100d tractor? Recommendations?
5,993
Pictures might really help, I'll bet it's a fitting or hose over being the actual valve body being bad.
4,211
Find the leak. I doubt its an expensive fix andcshould beceasy to find.
If its a constant flow pthe ŕimary culprits are onlet amd power beyond hosed and comnections.
And put the permatex away - very little if anything that needs it.
