How big a job replacing water pump? M4050
Airgator
Kubota M4050
Jan 22, 2022
31
Florida
How many things do I have to pull off to replace the water pump? Can the radiator stay in place? Do I have to take the fan blade off? Thank you. As you can tell I’m not a mechanic. I appreciate your wisdom and experience,
5,615
If you can get to and take out the 4 fan bolts then you don't need to remove the radiator.
then it's easy to remove the water pump.
1,135
You will probably save time taking the radiator out if it is relatively easy to do. On my older tractor there were two lock plates and four bolts holding the fan on. They were sunken into the fan and could not be seen from above or sides since the fan shroud extended a bit past the fan.
Removing the hood took about ten minutes and taking the radiator off took about another ten or fifteen minutes since I didn’t want to cut the hoses off so struggled with them a bit. After that getting the fan off and back on took about five minutes (fan tips had been damaged before I bought the tractor).
Your tractor seems to have some foam seals around the radiator that might need to be replaced if they are old and fragile so that might make it more trouble and expensive to remove the radiator. You may consider getting some inexpensive snake style camera to get a view of the fan bolts and how to remove them.
Good luck!
JohnDB
M4500DT
Jun 9, 2018
388
65
NZ
A trick is to use cardboard to keep the radiator fins from getting dinged.
Or thin plywood... anything that will stop you accidentally bending the radiator fins or damaging the tubes. Only takes a spanner to slip, or the pump suddenly freeing from the block ...
Or use the Russell King technique.
Airgator
Kubota M4050
Jan 22, 2022
31
Florida
Good luck!
Thank you!!!
Airgator
Kubota M4050
Jan 22, 2022
31
Florida
Thank you!!!
Thank you!!!
