Hazard lights only working on one side of BX series
Lymegrey
Kubota BX2670, Kubota BX2680
Sep 29, 2024
Northern Michigan
New here, but wanted to share a problem at work with a BX2680 (2018). Tractor would only flash hazards on one side, LH side to be specific. Wasted a few days tracing continuity and having very odd multimeter readings. Ended up chasing continuity back to the flasher itself, which received 12.5 V and gave 12.5 V to the rear LH (which then travels up in my case, through a Curtis Industries cab, to the front hazards).
On the other hand, it received 12.5V but was only giving ~ .78 V to the RH rear hazard. Plugged a flasher from another tractor in and it worked. Hope this helps someone out there.
