I'm having a problem with my GR2120 (99 hours). I just removed the snowblower and while trying to put the mower deck on I found the hydraulics won't lower the points where the deck connects. The hydraulic cylinder seems to go up but not down.
I checked fluid, and added a little bit, but I don't think this is the problem. The cylinder that activates up/down shows some fluid leak on it, but no drips are forming on the ground below it.
I checked that the connector that lowers the snowblower is securely reconnected, and its no leaking either.
And the grass is growing. ..
Thanks for any insights.
Wayne from White Salmon (WFWS)
