Hello, hoping someone can help. I don't seem to have a transmission fluid strainer or drain plug for the UDT. Could I perhaps have an early model without one? I'm assuming I just remove the metal pipe to drain an don't worry about the strainer? Pictures from the manual (showing what it should look like) and what I have below. All the pics I can see online show a strainer.
Discovered this while replacing the fuel lines and cleaning the tank to try and cure some rough running/bogging down that can be relieved by rocking or tilting the tractor to the left.
Cheers
Cheers
