It's your call, I've done it both ways.should i pull out the radiator to undo the 3 bolts on the shaft or battle away with the limited space with a spanner
ThanksAfter taking the deck off the three bolts are easily accessible from below.
Taking the radiator out makes it possible to work from above but I would only do that if you plan to change the coolant anyway or if you want to flush the radiator.
Thanks for thatI pulled the radiator on my 2501 when I was replacing a line one time.
The replacement cost of a new radiator when you "slip" and punch a hole through it, just wasn't worth it to me.
Over the years, I have "jacked up" enough radiators by hitting them with a tool, or something, to know that the extra few minutes it takes to remove the radiator is sometimes more than offset by the time saved working in tight spaces, and "slipping" or "dropping" something on the fins.
There have been exceptions of course, but not too many.![]()
