Fuse box location B1750.
mondopost1962
BC
Hello, I inherited a Kubota B1750 4x4 tractor. The temperature and fuel gage do not work. I want to check fuses but have no clue where they are located.
model D950-5B, engine serial number 717612. Thanks for any advice.
1,095
I think you may just have fuse holders and not a fuse block
From Kubota illustrated parts list, I see two fuses #110 and a fusible link #40
Mountainman
L2501, B7100, B6000, BX24, B1750, B2400
Jul 10, 2022
148
51
Attalla Alabama
mossycreekoutdoors.com
If you look under the hood left side I believe there are wires with a fuse holder. Has 2 fuses. Most of the time it's down between the fuel tank and side panel but should be able to grab it and pull it up
