Hi,
New poster to the forum, although I've cleaned so much good advice so far!!
I've a M108s Dual Speed, new to me and i'm slowly giving it a full service so I know everything has been done. I've followed the manual for a coolant change but only got half (5 litres) of the supposed 9.7 litres that should be in there. I'm assuming the half I am missing is in the block and not draining from the radiator drain.
Does anyone have any tricks for getting all the old coolant out? Is there a block drain somewhere (or bolt that goes into the water jacket) that I can use? Manual doesn't mention anything...
What are you all doing?
My new coolant is pre mixed so I can't really flush the system with water then put a stronger mix in to compensate (if you know what I mean)
Any advice greatly appreciated
Thanks
Thanks
