R RNP New member Equipment Kubota L3430 HST Feb 28, 2024 6 0 1 Tennessee Feb 28, 2024 #1 My Kubota L3430 HST's front wheels stopped pulling. I noted a sound like an old bulldozer clanking when I was backing up. Then, gradually, I noticed that the front tires stopped pulling. What is likely the problem?
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 11,317 4,853 113 Greensville,Ontario,Canada Feb 28, 2024 #2 busted U-joint on front drive shaft ?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,993 6,177 113 Sandpoint, ID Feb 28, 2024 #3 If you lucky it's just a couplers splines have been stripped. To start with you'll need to get into the propeller shaft and check the front coupling.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,993 6,177 113 Sandpoint, ID Feb 28, 2024 #4 GreensvilleJay said: busted U-joint on front drive shaft ? Click to expand... It doesn't have one.
