mcmxi
I'm converting the single battery system on my boat to dual batteries, and many months ago ordered the optional auxiliary charging cable that connects to a plug on the Yamaha engine and is used to charge a second battery. The ECU on the engine figures out which battery needs charging. With two batteries one can be used to start the engine which is all it does, and the other is used to run all the electronics and equipment requiring 12 volts. The idea is that the starting battery will always have enough charge to get home since it's only used for starting.
My confusion began when I noticed that Yamaha shows a fuse between the engine and battery on the auxiliary output for the second battery, but none on the connection to the starting battery. In fact, there's no fuse at all in the starting circuit so I had to do some research. It turns out that the American Boat & Yacht Council (ABYC) doesn't require boat manufacturers to put a fuse or breaker in the starting circuit. Their rationale here is that the current can spike significantly during starting which could blow a fuse or trip a breaker, rendering the engine inoperable. This could result in the boat and occupants being in serious danger, so that's why there are no fuses in boat engine starting circuits.
I also bought a Blue Sea Systems battery switch which closes the circuits for both batteries in the first position and combines both circuits in the second position in the event that the starting battery alone won't start the engine. Since the fuse for the auxiliary battery is between the engine and the battery, and the positive cable from the auxiliary battery goes to the switch, the fuse only has current flowing through it during charging but not when both batteries are combined for starting.
I've been doing a fair amount of wiring with 2AWG and 6AWG cables and a few months ago bought a neat tool that does a great job of crimping ring terminals onto cables. It does a professional job for sure and came with lots of different mandrels for various gauges.
