Fitting 60" Zero-Turn in 72"-wide Trailer?
Mr Haney
L3710
May 23, 2022
152
23
FL
I have decided I want a used ZD331 or ZD1211 mower with a 60" deck.
I have no trailer, and I may have to rent one to get a mower to my house.
The specs for a 60" deck say it's about 73" wide with side discharge. That will not fit most rental trailers. Can someone tell me if it's possible to remove things and get the width down under 6 feet? I would guess there is a chute that comes off.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,102
1,209
Near Lancaster, PA, USA
I'd ask the seller. May be as easy as taking a bungee cord to hold the discharge chute up.
Starman2112
Kubota LX2610 / Kubota Z421 54"
Jul 4, 2023
I have the ZD421 53" and always run it in mulch mode without the chute. I live in the pacific NW and its real wet in spring and fall and never have problems mulching and the Zero turn just dissapears anything it mows. I ran the chute for 1 year and it was an absolute mess, spewing the grass all over the place and making the lawn look bad from the clippings. This may be your width solution!
Mr Haney
L3710
May 23, 2022
152
23
FL
Thanks for the help.
I didn't want to rent a U-Haul and find out the mower would not fit.
1,387
Be careful on the rental. U-Haul often puts a narrow gate opening on their trailers (for strength?) so you need to measure the opening before you rent one.
Other rental places will have more standard utility trailers with full width opening.
4,810
Rent a car trailer from U-Haul and it will fit with room to spare. Just make sure that it is tied down well. The straps that U-Haul provides only tie down the front wheels and that isn't enough in most jurisdictions.
4,868
ZD331 can go 10MPH , so an easy 8 hr 'road trip' though I suspect you might need a new set of rubber afterwards.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,806
2,815
Can't help on narrowing the mower, but maybe a wider trailer can be had at
JasonW
286
135
Al
My ZD331 60” deck measures 65” with the discharge chute held up.
