Error code E9126 on SVL65-2
LVig
Track loaders
Jun 28, 2024
Houston
We replaced the ECU on our track loader with a used one, because original one stopped working. After that we started getting error code E9126... The manual does not list it, the dealer said it might have to do with "an injector". We registered all injectors into the new ECU but the error persists. Any ideas???
whitetiger
Nov 20, 2011
2,700
1,204
Kansas City, KS
An E:9126 code is a problem with the CCV internal pressure detection switch. They can be "NO" or"NC" (Normally Open or Normally Closed) depending on the engine serial number. The ECU that you installed is probably programmed incorrectly for your machine.
Machine serial# 16743 to 32379 is NC and machine serial# 32380 and above is NO.
Tell your dealer to look at TIB-2024-003-R1, SVL CCV Pressure Switch Lodgic. All you need is a simple software reprogramming.
