Electric PTO Clutch adjustment
FiveOrangesH14
Kubota T1880A2, Kubota TG1860G
Dec 26, 2024
40
Vancouver Washington
Owner of a TG1860G. What is the clearance of the electric PTO clutch? Couldn't find it anywhere but I might be missing something. I am worried that the clutch is potentially slipping as it makes a screeching stop once it is disengaged.
5,379
the screeching may be the bearing. Find out the make/model information as they will have the clearances you need to know and the pattern.
Usually you go N-S-E-W a turn at a time,checking each point.
Different makers....different rules though !
FiveOrangesH14
Dec 26, 2024
40
From what I have found, it is a Xtreme Electromagnetic PTO Clutch #0626. The site to buy it from doesn't have its specifications for the clutch plates though. Is it easy or possible to check and replace the bearing?
7,466
The screech could be the belt too.
Looking at that clutch the bearings are held in place with snap rings so yes easily replaced.
5,379
Just went to their website, they do not sell the bearings ! even though they're easily replaced !! Well, according to Chatty Ron. Hopefully you CAN see the bearing part number, so a 'bearing supply house' can sell you one($20 ,maybe ..)
Considering this is a $500 unit, I'm not impressed.
FiveOrangesH14
Dec 26, 2024
40
I can consider checking the bearings, but for now I still just need to know what the specification for clearance of the clutch is. No money spent is what Im after!
MOOTS
MX6000
Jun 27, 2019
2,022
2,383
Canton, Georgia
Its a metallic screech like metal on metal or something. Doesn't sound like a belt slipping and no smell.
I’ve dealt with the xtreme clutches on grasshoppers at work. Decent for the money, but self destruct. The air gap on the grasshopper model isn’t adjustable. The metal on metal screech is more than likely the magnet plate has broken its welds to the “hub”. I have welded them back, but they don’t last long.
Pull clutch and disassemble, you’ll know if it’s broken the weld.
MOOTS
MX6000
Jun 27, 2019
2,022
2,383
Canton, Georgia
Our scag mowers with ogura clutches want a .015 air gap. I recall our toros with Werner? clutches wanted the sameish.
