DPF Engine warning flash indicator
BwanaDon
Kubota L3301
Feb 27, 2025
Middleburg Fl
Just purchased a 2019 L3301. 151 hrs. Dash display was dead due to blown 5 amp fuse. When the fuse was replaced I got a solid engine warning light with alarm at 1 second intervals. Trying to follow the steps for idle regen in the manual but instructions are not clear at least to me. Would appreciate any constructive advice.
Manual says park the unit and contact dealer.....
7,263
If you look at the chart below, it sounds like your tractor is at PM warning level 4 so a dealer will need to look at it. Did you buy it with the fuse blown so didn't know about this, or did you buy it and then the fuse blew?
7,587
This line says it all!
It's sounding like you got taken advantage of. 😞
That tractor has to be running like poo. :poop:
That's a stage 4, you can't fix it.
It will require a dealer to do a computer controlled forced regen and even that may not make it work.
You may have to pay to have the DPF / DOC replaced/repaired.
I hope you don't as that's a $4K set of parts.
I'm slow typing, Yea what @McMXi said. ;)
BwanaDon
Kubota L3301
Feb 27, 2025
Middleburg Fl
Thank you for the info
