Do your brush hog blades "droop"
Vladhed
B2401DT, old rear blade, RCR1248 rotary cutter, MK Martin SB54 snow blower
Jul 17, 2021
27
23
Perth, ON
After a couple of years of use, I decided to take the blades of my RCR1248 to sharpen and check them for balance.
After I put them back on, and torqued them to ~400 ft-lb as per the manual, I noticed both blades were no longer "snug"! I took one of them off again and double checked everything was seated properly. Any hints? The keyed bolts seem to be tapered so you can only tighten the nuts so far, so it looks like the washer is the key. Should this be replaced?
Is this a big deal?
I went ahead and cut our usual walking trails and it worked like new.
re54drider
L2800, FEL, Bush Hog
May 9, 2011
66
Goldston, nc
Mine has done that since new. I made the assumption that it allows the blade to move away from rocks, etc as well as to swivel about the main shaft which allows the stump jumper to work. Maybe I'm wrong but I stopped sharpening my blades 7 years ago and see no real difference either.
Flintknapper
L2350DT
May 3, 2022
1,733
2,179
Deep East Texas
No...mine do not do that. I expect there is some 'wear' someplace allowing that to happen. Certainly not a design feature.
Centrifugal Force would tend to keep the blades on a level plane (unless an object were struck), so the mower should still cut fairly well under most circumstances.
Elliott in GA
Mar 10, 2021
718
698
North Georgia
The best practice is to buy new mounting hardware with new blades, and I would expect new mounting hardware would give you a tighter (but not too tight) fit with you old blades.
I plan to replace my blades this winter; I will have completed the last (really just some minor stuff now) of my 10+ acres of field reclamation work. My 3+ year old blades still cut grass surprisingly well, but they do have some real dings from rock strikes (no matter how careful - pre-inspection on foot and cut height set high- you are backing into a wall of weeds, brush and multiflora rose, you are going to hit things). I doubt that I will sharpen the old blades; it would just potentially create other issues.
SDT
multiple and various
Apr 15, 2018
3,206
1,011
SE, IN
Is this a big deal?
Should be little slop between blade bore and blade bolts.
Blade bore and/or bolts is/are worn.
Washer?
1,272
As everyone has stated the blade is NOT clamped by the bolt. It has to be able to rotate 360 degrees around the bolt.
It is sort of like a (cheap) lawnmower wheel attachment to the deck. The bolts are shoulder bolts so the nut is pulling against the shoulder not clamping the blade tight. The wheels spin around on the stationary bolt.
I also agree that it may be a bit excessive and you need to replace the hardware and the blades at some point to eliminate that slop. But you could also go to where they sell new brush hogs of the same brand and see if they are loose on new or slightly used equipment.
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
402
282
Nazareth Pa
Is this a big deal?
400 ft lbs. How long was the pipe on the wrench and how many people were pulling it?
