Diesel Transfer Tank -Barometric Pressure Valve?
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,156
853
PNW-WA
As many of you are aware, I built this Diesel Transfer Tank.
Someone (here or elsewhere) suggested a one-way Barometric Valve, but I cannot seem to track down that info... I thought I'd bookmarked.
Does anyone have a suggestion for a 3/8" NPT (one-way?) valve?
Help is appreciated!!
6,058
I'll have to dig into my past purchases to see where I got mine.
BAP
Dec 31, 2012
2,702
810
Search “Fuel Transfer Tank Vent” on Amazon and there is all kinds of them in different styles.
Trimley
Jul 25, 2023
1,156
853
PNW-WA
That would help me out a lot.
I've searched Amazon, Google and eBay with about every search term I can think of. I'm not finding a barometric pressure relief.
2,635
Trimley
Jul 25, 2023
1,156
853
PNW-WA
2,635
As a 2-way vent, yes. The problem is, it would breathe in both directions and pull moisture in.
What I'm wanting is a breather that opens only by internal built-up pressure. Atleast that's my understanding.
I don't understand.
Then why have a vent?
I guess I am having a hard time picturing a "one way vent".
If the fuel gets hot and expands, and the vent is only one way, wouldn't that create 'vacuum" situation when it cooled off?
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
198
94
Fayetteville GA
I don't understand.
Wouldn't also make it hard to pump fuel as it would only have a one way valve. Collapsing the tank?
old and tired
L2800 HST; 2005; R4
Thinking outside of the box, wouldn't an expansion tank (like for hot water heaters) be what you want? Rubber bladder that expands and contracts but doesn't let outside air in...
{EDIT} Oops, forgot about dispensing fuel!!!
Trimley
Jul 25, 2023
1,156
853
PNW-WA
I don't understand.
I agree. I'm kind of baffled at the necessity. A 1-way? (Shrug)
I already have/had a breather, so why the need?
I'm new to diesel, and to building a tank!
Smokeydog
Jun 2, 2020
654
596
knoxville, Tennessee
It’s a vacuum pressure vent. 1psi vac, 2psi pressure. Keeps vapor pressure above the fuel in to keep the humidity or water out. Reduces loss of evaporation of fuel. Us who live in high humidity need to store fuel this way.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,757
2,753
Most ATVs have spring checks on the fuel cell. My Can Am does. Allows venting if the pressure goes too high. Allows air in if there is too much vacuum. Is that essentially what you are looking to achieve?
6,058
Trimley
Jul 25, 2023
1,156
853
PNW-WA
I think what you're describing, is what I'm needing. Are they available in 3/8"? A link is appreciated.
2,635
I am not a "tank builder", but I did retrofit a tank from a boat and adapted it to fit in my truck bed.
I used a simple "elbow" to vent it.
I have never had a "water problem" in the 5'ish or so years I've had it.
But then again, I have never had any of the problems with diesel that I hear so much about.
Maybe I'm just lucky.
It holds ~70 gallons plus the original tanks ~38 gallons.
It's nice not to have to stop for fuel for about 1600 miles.(y) (although my bladder can't do that)
Although filling it takes a little longer, and paying a $400-$500'ish bill sucks.
My "Google Fu" must be weak, cause I can't find anything like what your asking for, but please post a link when you find it cause it's driving me mad. o_O
Sidekick
Jul 29, 2023
500
425
N.Y,
Years ago I designed some medical equipment for cooling a body after heart surgery that needed expansion breathing on the liquid tanks hooked to the catheter. I used vents that have a membrane that allows air to pass but blocks compatible liquids. They were called hydrophobic vents. You would have to verify diesel compatibility. They did not let moisture or liquid to pass. Many outdoors sealed nema enclosures use them for venting.
Trimley
Jul 25, 2023
1,156
853
PNW-WA
I did, originally. Unless I missed it, all I found were different types of 2-way breathers?
