D850 Steel balls on/near the crankpins???
Kenbo
Kubota D850
Mar 23, 2025
Jersey Shore
Hi folks,
First-time poster, long-time lurker. I'm disassembling a D850 engine with a bent connecting rod. After disassembly, I looked at the exploded parts diagram on Messick's (B1550E used the D850 engine) to get part numbers for what I needed, and I noticed this part #110 in the diagram: #07715-00401 BALL, PISTON CRANKPIN. I was conscientious when taking the crank assembly apart, and I didn't see any steel balls, nor did any fall onto my workbench.
What gives? Does anyone know where these balls go and what their purpose is? I have never seen steel balls used in any other engine I have worked on. Does anyone have any experience with these 70 Series engines and can enlighten me? Thanks in advance.
7,978
Your first problem is you added the word steel!
They are aluminum / alloy balls and they are plugs for the cross drills on the crank to the rod journals.
And they are not removed!
7,978
Thank you! Very helpful.
I see those plugs on my crankshaft. I assumed they were steel based on the pic on the Messick's website.
The replacements might just be soft steel.
So my apologies, I just looked at a D850 Crank I had here.
Kenbo
Kubota D850
Mar 23, 2025
Jersey Shore
No apologies are necessary. Looking at my crank those plugs are dull metal so they don't look like steel. Again thank you otherwise I would be on my hands and knees crawling around my shop looking for those balls I obviously must have dropped lol.
