Does anybody know the specs on a d750. There is nothing wrong with my engine yet I'm just trying to find out as much info as I can before I go buck wild with a motor swap
The short answer is a D750, D850 & D950 will all interchange because they use the same block. If you go to a D950, you need to find a bigger radiator because it makes considerably more heat when working hard.
