I have a RTV900 that cracked the head. We rebuilt the whole engine and put a new head on (a head that came already assembled with valves). Got it all up and running and it seemed to run fine. After about an hour of use or so, it "popped" and upon inspection it had broken the #1 exhaust rocker arm. I thought it was weird, but ordered another. Checked to see that everything was moving the way it needed, double checked timing and valve adjustment, got it all back together and it ran great. However, again after just short use, it did the same thing and broke the exact same rocker arm.
This time I pulled the head and looked everything over. All valves appeared to seat exactly as they should. There did not appear to be any restrictions (that I could tell). I double and triple checked my clearances and put it all back together. It fired right up and ran nice and smooth. As soon as we took it out to do a little work it did the same thing AGAIN! I have previously talked to 2 Kubota mechanics and followed instructions for set up and inspection. They both verified that it appeared I had done everything they way it was needed. But, now I am just completely stumped and a bit frustrated. Do I need to look at another head? Can it be something else? I appreciate any insight. We use this machine on a school campus, and it has been frustrating not having it in service.
