Bx2670 mower deck step cam
mrcj
BX2670
Jul 22, 2023
17
Kentucky
BX 2670 60inch deck, Guys, I need some help...
I replaced the step cam mechanism that holds the deck at desired cutting height. The old one was chewed up and wouldn't hold the deck, it kept slipping. Now, the hook on the end of the linkage that contacts the notches in the step cam will not make contact with it. When I lower the deck, say on 3.5 on the dial, the deck just drops. I looked under there and its not close to making contact. Its like its to short.
On the other hand, when at set the deck at full height and turn the dial to TOP , and lower the lift, the mower deck stays in place like it should
I have plenty of thread showing past the nut on the rod thread and it looks no different than the old install. What Im I doing wrong??
