BX25D Four-Wheel Drive Shifting
stevewhitts
BX25D
Mar 5, 2025
Maryland
I have a BX25D with 366 hours on it. I find that shifting out of four-wheel drive to be very hard. I've tried lowering and raising the idle speed. I've tried tapping the drive pedal both forward and reverse. I've tried putting in in neutral. It will finally come out of four-wheel drive, but I really have to pull hard on the lever and I can't seem to figure out if all the different things make any difference. The last time, I shut the tractor off and then took it out of four-wheel drive. That was a little easier but still had to pull hard on the level.
Any suggestions?
2,737
place your FEL on the ground,curl down and raise the front end off the ground a bit - it will go in and out with ease.
NorthwoodsLife
Oct 15, 2021
1,128
1,062
Wisconsin
^^^ This ^^^
And try driving in a straight line for a few feet to relieve gear mesh on your front driveline. Steer left and right a little might help as well to unload the front driveline.
Coming out of 4WD should be easier than going into 4WD. I would guess that there is a treddle pedal adjustment needed.
William1
BX25D
Jul 28, 2015
1,179
378
Richmond, Virginia
I press the lever slightly and rock the fwd/rev treadle, moving a few feet back and forth and it always slips out then. It is 10X harder on hard surface, so be on gravel/dirt/lawn. Needs the ability to slip slightly.
NorthwoodsLife
Oct 15, 2021
1,128
1,062
Wisconsin
On a side note...
Is that Mickey Rourke?
stevewhitts
BX25D
Mar 5, 2025
Maryland
Tried this yesterday and it worked great. Thanks. Will try the other suggestions next.
And on a side note - Confusing Steve Martin for Mickey Rourke???:ROFLMAO:
