You let it sit for a day. Did you pull the glow plugs or injectors prior to starting?
Sounds like pump could have lost prime, but hard to know for sure with the tip over what else might have happened
Given the tractor was on its side, I’m reluctant to offer advice that could be more deleterious to the machine given the circumstances.
How is the level on the motor oil dipstick?
How “low” was the hydraulic fluid when you filled it? Antifreeze?
Did you see spillage of hydraulic fluid or antifreeze on the ground when it turned?
Howdy, thanks for the reply.
since it started back up next day without issues, I did not bother to check the glow plugs or injectors.
did not think those would affect the hydraulics. but I am just a end user, not a mechanic
motor oil was perfect. hydraulic fluid at the transmission was low about 2 quarts, but I did not see any spillage. could have been like t hat, just bought it in Sept. Antifreeze did leak out, added about 1 quart to that.
Is there a way for me to prime the pump? that's what I thought it might be, but again, no mechanic here.
