Hey Gents, the last few times I have had the tractor out, I have encountered some steering issues.
1st time it happened I was moving some recycled asphalt, then again while mowing, twice. What happens, is I turn the wheel and the wheels do to move in that direction. Last time it happened, actually this past weekend, I had to turn all the way to the left before the power steering started to work again, even then it was not as good as it should be.
I thought I might have low hyd fluid but when I pull the dipstick out at the tranny, its full. I did replace some hyd fluid after one of the front loader cylinders developed a leak, which I had both lift cylinders re-sealed.
Or do I have an issue with the steering valve assembly, if so, is it rebuildable?
thanks for input
thanks for input
