BX Lift pin
3,289
OK guys what size is the lift pin that attatches the 3 point to the mower linkage Some how I lost mine. So before I run to the stealer I might have something here that might work
2,955
Could you not just measure the hole?
Not trying to be a smart a$$...maybe there is a reason you can’t...
3,289
I wish, them I got the one I need goes through the 3 point lift arm to the lift linkage for the MMM,, I think it looks like a 7/16 maybe. and its not very long,, I may have to modify a bolt and a lock nuts for the time being,,, kid at the parts desk says we dont have any in stock! I asked the kid , annnnd? Well I guess we could order one,, you need washers and the pin for it,,, duuhhhh
3,289
Well it is up and under things unless you take the wheel off,,, thats not bad,,, unless it is filled and you have a wheel weight on it and yes I do,,lol Though I may wind up doing just that,, talk about a PIA for a fat old crippled guy :)
2,516
Skeets - what is your mower number? RCK54 ?
2,516
THis any help? I am guessing on deck model
3,289
No it is a 60 inch, the lift arm that is pinned to the 3 point arm is the one that went missing,, I did find a bolt that matches the hole in the lift arm , I cut it off and drilled it for a clip so I think it will work for a bit until I get the pin, if the clown at the parts desk ordered the damn thing,, no we dont have any,, wellllll ,,,, I guess we could order it,,, Ahhh duhhh I really dont need it,, I just wanted to make you look,,, stupid kids! YEAH ORDER IT !
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
212
75
Bloomsburg
From your post, I presume your are referring to a rear mounted mower and not a MMM as you mentioned the three point which is the at the tractor rear. A BX has Cat. # 1 lift pins which are 7/8". Top link is smaller at 3/4". If you are referring to the MMM linkage, see 85hokie post. There you have it.
whitetiger
Nov 20, 2011
2,914
1,376
Kansas City, KS
Reread post #4
4,810
Reread post #4
This is where you have created the confusion yourself. You said "3 point lift arm ", and there is no such item under the tractor for the MMM (mid mount mower). I can understand your not knowing the proper nomenclature for a part, however, everyone here is attempting to help you. It is called a lift arm. If you had put the model number of your tractors MMM into the post, any one of us could have gone to the www.messicks.com website, and looked up the part that you have lost, and helped you.
When you get sarcastic with a response like you did in post 10, then most people stop helping.
5,102
You’re responding to a post from last year. Skeets has since bought another tractor, although he does still have his BX.
