Found three 6.00mm balls on the concrete in front of the BX. I haven't had any other equipment in or out that I can remember, so instinctively, I'm worried about it being the BX since it's pretty new to me.
What bearings are in the tractor? The balls are too big to be from hydraulic fittings, and all of those look good. The BX has a mower deck under it, but everything looks okay with a quick inspection. Took it out to mow a bit and it was smooth and quiet. The 6205 spindle bearings use 8mm balls, so those don't seem to be an issue.
What other bearings should I be checking out?
Might not be from the BX at all, but I want to rule it out before looking elsewhere.
![](https://i.imgur.com/VhE5LvB.jpg)
