Bx 2370 Knob height Problems
bluelight16
BX2370
Sep 18, 2022
17
11
Problems getting the knob to turn to top position, once I get it in the numbers I can rotate thru, 0 to 4 no problem but when needing to go to top position I have to get the weight from the mid deck off, I tried adjusting the adjustment bolt but could not get the link to any where near the stop position requirement of .02 in. Any suggestion would be appreciated.
Orangeglow
2015 BX2370
Jun 19, 2014
344
160
Prescott, Ontario
On my BX2370, I rev the engine to 2K rpm, and lift the mower up until I hear the hydralics go into bypass mode. Watch the mower as it lifts. The front goes up, and the rear should lift just a little bit higher. Then I rotate the control knob clockwise, until I get it to the desired position. I find it works best for me if I only turn the control knob clockwise.
Sidekick
Jul 29, 2023
869
1,045
N.Y,
I had a problem with that just before the rod that pulls the mower broke. Deck wasn't lifting high enough. It's a common problem on the 2360. Here's an old video
