BX 23
TV Kubota BX 23
2005 Kubota BX 23 with loader & Backhoe
Nov 21, 2023
Maryland
Hello,
I have a 2005 BX23 and it travels faster in reverse then forward in low gear. Can someone explain the process to adjust the forward speed please. Thanks
whitetiger
Nov 20, 2011
3,065
1,512
Kansas City, KS
Hello,
Check the tierod ends on the linkage from your hydro pedal to the hydrostat. The nut on the rear of the linkage rod tierod end will probably be loose.
Lay under the tractor, engine off, using a flashlite you can see the linkage while you move the pedal from forward to reverse and back.
