Buying rims online?
ridgerunner85
L3200
Dec 19, 2019
PA
Has any ever bought rims online?
I have R1’s on currently and want to upgrade to R4’s on my L3200. My current tires are filled with Rim guard. My dealer won’t reuse the Rim guard that I already have in the tires. My local tire shop said that they could reuse it, but they didn’t want to or couldn’t get me the appropriate rims. Plus the dealer is about an hour away. Figuring it would be a lot easier if I could just order the rims online.
1,201
You might want to order the tires on rims through a saleman at the dealership. They are whole-goods and can be cheaper than rims and tires separately.
You may need to change the front wheels and tires also if your tractor is 4 wheel drive so the ratio of tire circumference stays constant.
4,621
FYI
rear tire ONLY for bx23s is $500 canucks...
rear tire MOUNTED on a rim, full of air with valve stem is $350
I don't understand Kubota's business model.....
ridgerunner85
L3200
Dec 19, 2019
PA
Yeah I’m going to replace all the tires.
The price I got for rims and tires from the dealer was very good but that didn’t include rim guard. Plus they don’t have a way to suck the rim guard out of my current tires to reuse in the new ones.
4,621
if you're not going to reuse the old tires
place tire in a large container,remove valve core,rim guard comes out,drill hole in top of tire,use compressed air to 'help' the rest of the RG to come out.
if you need the old tire, just clean the hole, and put a plug into it.
4,572
You can purchase a device for installing the Rim Guard in a tire. Just use that in reverse to remove the Rim Guard and put it into 5 gallon pails. Then reverse the process and install it in your new tires. If your old tires are good, then sell them with the rim guard to someone else that wants weighted tires and rims for their tractor. The Rim Guard isn't that expensive, but the labor to install it is the expensive part.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,239
1,666
Western MT
I've had good luck buying used OEM rims for cars/trucks on eBay. That might be worth a look.
