I used my 48" sidewinder bush hog as my first pto drive implement on my new to me tractor. I was running it in PTO drive 1 and it seemed awfully slow and quiet. I put it in PTO 2 and it really began to shake and wobble within only 5-10 seconds, so I put it in neutral and got it to N to stop it. I put it back in 1 after it came to a stop and cut about 250 ft with a couple turns/turnarounds. I notices a trail of fluid and the neighbor came over and said I had a busted seal as I had just realized it and was still on the tractor.
I did a search and think I can easily replace it, but I have a couple questions. Is there a good chance I damages the bearing in the PTO housing just inside the case? I went ahead and ordered it since it was cheap enough from the dealership. My B7100 gear drive does not have the ring with the intentions to pop it out from outside. The neighbor also said there was water in my fluid. At this point I plan to train off what is left and open up the back plate. I will clean it up if I see any metal bits. And put new fluid in it. Is there another part(s) I should be mindful of when looking in there and should I just replace any parts because I am in there. It is a 33 yo tractor with at least 1200 hrs and the meter doesn't work as of now. I assume it has been kept in good, but minimal cost care condition. It is faded like it has seen more days outside than in.
Thanks for any input!
