Hello all, new member here after lurking and getting many questions answered that way.
I attempted to search and can't seem to find much on control valve rebuilds... hoping one of you can help me out.
I have been fighting with the control valve on my BT600 backhoe. After finding a pretty substantial leak around the top of two of the spool control rods, I took it off the tractor and replaced all O rings throughout. (Ended up finding metric O rings to fit and making two of the wipers by sanding thin a plastic washer of the same diameter, rather than pay $50 for the pack of two O rings and wipers from Kubota.) Put it all together and leak was fixed.... for a day. Four hydraulic lines later and the leaking control valve is back again...
It now seems to be leaking from the bottom of a few of the spool rods, where the caps cover the spring assembly. Haven't taken it off the machine yet to see exactly what spool but it is from the bottom this time, not the top. In your opinion should I go ahead and bite the bullet with the Kubota O rings and wipers? Could the O rings that appeared to be exact be slightly off allowing leakage? Any other things to watch out for? I am mechanically inclined but this was my first go at hydraulic valves.
I am in rural WV with nothing in the way of hydraulic shops to take this thing to for a rebuild either. One place I did find over an hour away wanted close to $1,000 to rebuild assuming it wasn't leaking between spool assembly themselves. Only 800 hours on the BX22 that its off of, way way less than that on this backhoe. Noticed control assembly is also discontinued from Kubota as far as just replacing the entire control valve, but for that price I could just buy a used BT600 from someone.....
Curious on your all's thoughts on how to proceed and if anyone else has had control valve issues.
