Broken Switch Wiring
Doug69
L3901
Mar 21, 2025
Boerne, TX
New guy with a 2014 L3901 (300 hours). I ran over a branch that bounced up and sheared the 2 wires off of a switch underneath the chassis about where the brake pedal is located. It's a boxy little switch that is adjustable. Tractor immediately stopped running, throws error E20 (if I remember correctly).
Q: What is that switch called, what does that switch do, and how can I fix it? And, how can I clear the code error?
Thanks!!
Doug69
L3901
Mar 21, 2025
Boerne, TX
Yes, mostly. What apparently happened when the branch severed the wiring, it shorted the ECU and popped the fuse. I replaced the fuse and removed the switch so I can repair/replace it. Everything works fine now though.
