D Drwkubota2610 New member Equipment LX2610 Cab Tractor May 15, 2024 2 0 1 Thunder Bay, Ontario Jun 17, 2024 #1 Looking to fund out if the backhoe from a rope l series tractor will fit a lx2610 cab model. The backhoe was on a rope tractor and has the separate seat. Just wondering if the subframe would be the same?
Fordtech86 Well-known member Lifetime Member Equipment L3200 Aug 7, 2018 4,976 5,912 113 Pineville,LA Jun 17, 2024 #2 The back hoe will work, but the subframe is different between a L and Lx. The cab model also has a spacer
beckmurph Well-known member Equipment Kubota LX2610TLB/Woods finish mower/woods rotary cutter/ Aug 23, 2012 301 253 63 catlettsburg, ky Jun 17, 2024 #3 Fordtech86 said: The back hoe will work, but the subframe is different between a L and Lx. The cab model also has a spacer Click to expand... Those spacers are around $1100. Reactions: 1 user
