BH 90 on a L3560
Geocom
L3560
Apr 26, 2022
Hi guys,
Just wondering if anyone has either themselves used, or have seen a backhoe 90 attachment used with the L series 3560 hstc cab model?
I know the Kubota dealer recommends only the BH 92 for the 3560 and their explanation as to why was due to the subframe they sell for the 3560 is only compatible with the BH92. However he did say with an adaption and re drilling holes it could maybe work.
Is there somewhere else that makes subframes more accommodating to host different BH's? Any help or prior experience on the BH 90 applied to a 3560 cab model would be appreciated.
Thanks, George.
jajiu
Jun 5, 2016
455
111
Rowley, Massachusetts
Why do you want the BH90 vs the BH92? I added the BH92 to my L3560HSTC and have nothing but good to say about it.
Geocom
L3560
Apr 26, 2022
There just happens to be a used BH 90 with 50 hours on a private sale available at a great price point.
loggin
MX4700
Sep 4, 2021
101
36
canada
It may be possible. Here is a video of a BH90 on an MX5100. The MX5100 also uses the BH92. I believe the BH92 came out a mid way through the model run of the MX5100. You would have to compare the mounting points of the two backhoes when they are disconnected from the sub frame. If they have the same dimensions then I would think it is just a matter of getting the appropriate sub frame for your tractor.
You would also then need the hydraulic lines for the backhoe.
I hope this helps!!
Tony B.
L3560
Jun 16, 2024
Arkansas
I purchased the same tractor L3560. Out of curiosity what will it cost for the undercarriage frame and additional hydraulics needed for the backhoe attachment?
4,536
A very ugly number,.....I suspect.
