Battery powered fuel transfer pump?
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
185
64
Had enough!
I heard about using a battery powered fuel pump to transfer diesel from a fuel container to the tractor fuel tank. Sign me up!
Any recommendations? Brands? Sources?
Thanks!
JimDeL
Aug 31, 2022
293
308
Austintown, Ohio
Old Machinist
May 27, 2024
84
NE FL
JimDeL
Aug 31, 2022
293
308
Austintown, Ohio
I've had a half dozen of these in the cheaper version and they all start to leak. Has this one held up?
For the past 2 (maybe 3) years. It's gone thru several batteries. Pumps about two GPM with a couple feet of lift.
Old Machinist
May 27, 2024
84
NE FL
I think you got a good one!
I just sorted the reviews by most recent and 4 out of the first 8 complained of leaking so I guess I will stick with the $15 ones. They last a while but all seem to start leaking at seam where the hose outlet is.
Kennyd4110
Vendor Member
Sep 7, 2013
1,222
406
Westminster, MD
www.boltonhooks.com
I saw these at the recent Equip Expo I went too:
This is the best version of this style I've seen. Nothing like the crappy metal chinesium ones sold everywhere,
I personally use the Flo-Fast system with the hand pump, so no batteries or electric to deal with. It works great.
John T
2017 BX23S
May 5, 2017
802
279
under a rock
Had enough!
Thanks!
I bought one from HF about 7 years ago.... has worked flawlessly.
I use it to draw off my garage heating oil tank... (off road diesel)
I just pull the tractor up / plug the pump into my battery tender pigtail off the tractor... and I'm in business.
best investment.
sure beats filling 5 gallon cans...
5,040
I don’t have the Amazon link, but this one has been good for a couple years.
Does almost 5 gpm as I recall. Just pumped out a 5 gallon can recently. Went pretty quick.
2,488
My wife bought me a "more expensive one - $85", and it has lasted for about 6 years and still works well - I bought one from HF and it lasted ................ about a year!
Old Machinist
May 27, 2024
84
NE FL
best investment.
I have one like this I use on my storage tank. Works great! It started to leak once and was pretty easy to replace the seal in. Been in use about 8 years and maybe 4 since I resealed it. Probably about due again but I did put a nitrile seal in last time so it may last longer.
xrocketengineer
Nov 14, 2020
744
639
Merritt Island, Florida
I have been buying the cheap HF pumps and some times they leak right off the bat at the hose connection to the pump. Pulling the black ring and hose off and applying a little bit of JB weld before reinstalling the hose and ring, makes a leak free pump.
