Was Joe Smith working for Kubota at some stage?Bad robot
That robot needs to be fired!
Does that torque tube pierce the rectangular tubing that makes up the loader arms? In other words, can you see through the tube when standing to the left or right of the loader? I'm trying to understand how those welds would have broken if the tube pierces the loader arms, which is the strongest way to build the loader.My FEL broke today.
2022 LA340 on a BX23s
I'm no professional welder but, something just don't seem right.
One side broke completely, the other is ready to be completely broken.
View attachment 151483 View attachment 151484
NopeDoes that torque tube pierce the rectangular tubing that makes up the loader arms?
It does look like it's butt welded. My loaders have the torque tube passing through the loader arms which is much stronger.It looks the same as mine did, NO 'penetration'. Tube is 'butt welded' not pierced.
While mine was 'out of warranty', KubCda did inject some coins into my account,that of course they got back a few months later![]()
MIG requires clean metal. That shop may not remove the mill scale before welding.Gas shielded mig is a great process but unfortunately it can make poor welds look great to the uninformed. It's really sad there's so little quality control where that loader was built. I wouldn't settle for less than total grind and reweld all joints on the loader,,,,at someone other than my expense.
I've seen my share of one-sided cold wells from Kubota.My FEL broke today.
I'll be watching mine like a hawk now that more folks with a BX series tractor are reporting this. This should not be happening.Hell, I weld better than that. No penetration….nice quality control. Wonder how many other crap welds there are. I will be checking mine over…
I'm waiting to hear back from the dealership. Problem is, even if I get a new one under warranty, how long until that one breaks?I dunno,......
That second pic does not look like a "robot weld" to me.
To my un-trained eye, it appears a little "uneven".
Now the big question is....Are you going to have it ground and re-welded, or are you going to modify it and make it go all the way through and welded on both sides?
"Enquiring minds" want to know.![]()
Who cares about elephants (well, I do care about the ones in Africa), but loader arms can be subjected to significantly different forces on each arm when raising a load, which can subject the arms to high torque stresses. That torque tube wants to rotate about its long axis under load, particularly unevenly distributed loads, which puts the butt welds under a torsional shear stress and that's what's happened here.I KNOW a proper butt weld has survived my 'testing' since it was done. Actually was told to not be 'gentle', and I have a lifetime warranty on the welds( he did both sides....).
To make a thruhole,you'd need to precision drill 2 holes and use a long tube. Not really needed as loader doesn't lift elephants !
