B7200 4WD Weak/Bleeding Off 3point hitch
Dunnmont
B7200
Apr 28, 2025
Houston
Trouble withB7200 4WD
Over past several months 3 point hitch getting weaker and not going as high. 3 point will also not stay up and leaks down, Fluid good and screen clean……tractor 35 years old….pump going out and bypassing internally ? Suggestions…?
Tom
4,797
Tom
Bad pump wont cause leakdown. First thing to check is oring in lift piston. Raise lift amd fully close lowerimg speed valve. If ot leaks down with the vslve closed the o-ring is leaking.
