My inability to find things here is vexing - it seems unlikely hydraulic flush info on such a common tractor wouldn't be here, but I can't find it.
I got this tractor last Fall, and now Spring is looking immenent I'm changing the fluid out, put new seals in the 3pt hitch piston, and am generally doing maintenance. I've never changed hydraulic fluid on this scale before, but it seemed like it shouldn't be any more difficult than oil or brake lines. There are two drain plugs on the B7100D on the back axle, easily accessed.
My issues are one plug didn't result in normal looking hydraulic fluid. It was some brown goo that was significantly more viscous than I'd expect hyrdaulic fluid to be. The other plug let out about a cup of water, then more normal looking hydraulic fluid followed. Now that it's "empty" I also cleaned the hyrdaulic filter, which seemed perfectly normal to me. No gunk, no clearly beading up water, no shavings.
I'm thinking a Real Good Flush is order to get all the gunk out, but I'm not sure how do go about that. Do I fill it, run the hydraulics a bit, then drain it? Do I use some special "hydraulic flush" stuff to clean it? Something else?
I'm also wondering why it wasn't just dirty hydraulic fluid? Air ingress? Another post on this forum was about that sort of thing, and it could easily be happening here, but I don't know what muddy looking viscous fluid is a symptom of.
Thanks for your time...
