Hello,
I have just tested the voltage from my battery leads whilst the tractor is running, without a battery connected and I got about 1.2V at full RPM. I tested the Dyno wires and I got the correct voltage in AC (I think up to 30V). I assume that I should be getting 12v feeding back to the battery? if so, is the regulator the most likely problem here.
Thanks
Matt
Thanks
Matt
